have tried everything I can think of need help...i have a zenith dvc2515. I went through the hack for vcd and the player read fine but will not play vcd at all tried nero5.9.9.0 and easy vcd on both cdr and cdrw to no avail...any ideas?
Is your player capable of playing cdr or cdrw, as I see from the compatability list that some zenith players won't play them, I can't see yours listed though. Try copying an audio cd and see if it plays, if it does'nt then I am afraid you are stuffed.
Craig -
Mabs I have a toshiba cd-1200 so its close and probably the same.
I have not found a CD-R that will work. But if I burn the VCD on a CD-RW then it works. It has worked on HP and Memorex CD-RW. It seems to like the smokey gray dye they use.Not only am I perfect but I'm Canadian too! -
No, audio cdr and VCD have nothing to do with each other. I was trying to narrow down the problem, some players wont play VCD, some wont play CDR, and some wont play CDR or VCD. If you say you can play a copied audio cdr then you have eliminated the fact that it is not a cdr compatability problem. Providing you are using the same brand of disc for making your VCD. Some players are fussy and will only play certain brands of CDR. It may be that it is the VCD format that your player can't handle, does it say it can play VCD on the box or in the manual.
Craig -
Craig,
I have a DVD-ROM and a CD-R/RW drive. I burned it using the CD-R/RW drive and then tried to play it back in the DVD-ROM drive. But it will not play. But if I put a store bought DVD into my DVD-ROM drive it plays fine. Are u saying that I should try viewing or playback of the burned cd into my CD-R/RW drive? This is all new to me, it's something that I find interesting and would like to be successful in doing.
[Help] Problems creating VCDs.
By scott274 in forum Newbie / General discussionsReplies: 77Last Post: 15th Jul 2008, 03:43 -
Multiple VCDs in one DVD
By vid_n000b in forum Authoring (DVD)Replies: 27Last Post: 30th Apr 2008, 03:52 -
I want to play VCDs on my laptop
By Michel-lyn in forum Software PlayingReplies: 2Last Post: 22nd Dec 2007, 11:38 -
I can not play some VCDs on my mechine. Can U help me ?
By wapw in forum Software PlayingReplies: 2Last Post: 21st Aug 2007, 12:46 -
extracting jpegs from vcds
By pk475 in forum Authoring (VCD/SVCD)Replies: 2Last Post: 9th Aug 2007, 11:38
