Okay I am new to this and I am not using that great of a system. A P2 400. I have downloaded other drivers for TV wonder VE and have tried the guide I found on the first page and I am having problems dropping frames. My CPU usage ranges between 6% and 50% but I am still dropping frames. Any help would be appreciated.
How many frames are you dropping, make sure you have nothing running in the background, what resolution are you capturing at, are you capturing to a seperate hard drive, what is its speed and size, is it defragged. Your pc speed is right at the bottom range of what is required for reliable video capture, so anything you can do such as shutting down unecessary applications and defragging hard drives will help.
Craig
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 23:33 -
Dropped Frames
By SudsMalone in forum Capturing and VCRReplies: 4Last Post: 21st Feb 2011, 06:31 -
You Get dropped frames? That's for you
By themaster1 in forum Capturing and VCRReplies: 2Last Post: 6th Dec 2009, 23:21 -
Dropped Frames
By dano404 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th Mar 2008, 14:57 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 21:59
