I am converting interlaced DV camcorder stuff ntsc 704x480 to svcd. I still notice some microblocking whenever there is movement which I find mildly annoying. So I wonder if anyone knows:
1. On the mpeg configuration under video tab and video format, should the interlaced box be checked?
2. Under Advanced tab, I always check interlaced as video source type. Does anybody have a way to check the field order correct? Is the only way to see is to output it to a real TV and look for jumping or can you see the jumping on the tmpgenc preview? I tried the suggestion of checking de-interlace filter and watching on preview and I can't see a bit of difference.
3. Should I try soften block noise. My box is kind of cut off but I can see part of two boxes with percentage below. I can't read what they are. But If I use soften block noise what values should be entered in each of these two boxes?
4. Also since I am using and miniDV camcorder, should I be clicking "output data YUV as basic YCbCr"? Is that designed for camcorder DV users like me?
I appreciate any help I can get. Also, anyone think I should be using 12i instead of 12a which I have been using?
Threev
<font size=-1>[ This Message was edited by: threev on 2001-08-11 02:46:05 ]</font>
Results 1 to 1 of 1
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 08:45 -
Settings for BD to AVCHD
By niz_se in forum Blu-ray RippingReplies: 1Last Post: 4th Feb 2009, 10:39 -
Best Settings
By devdev in forum DVD RippingReplies: 2Last Post: 26th Jan 2009, 10:46 -
HD Settings
By kiwikiwi in forum EditingReplies: 9Last Post: 13th Dec 2008, 16:20 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18
