if you use NTSC FILM framerate it becomes less or more offsync?
Results 31 to 37 of 37
more i think. ill try doing it in different framerates, i havent actually tried that yet - doh! the video plays like crap though, so its not just that its offsync.
alright i just encoded a chapter. it plays fine to begin with, but then it stops playing the video while the audio keeps going. im clueless now.
You said you encoded something with 0.0.2, could it be that you used GOP=240 as this was the 0.0.2 default (intended for DivX encoding)?
A value of GOP=12 should always be used when encoding to mpeg-1. -
So I went to burn the MPEG files I made with 0.0.3, first using GNU VCDImager then Toast, then using the XVCD post-processing step in ffmpegX then Toast. Both burns played back really choppy, although they played remarkably smoothly in Quicktime. I went back and re-encoded the program at a lower bitrate, thinking that was the problem (first bitrate entered was 1536 for video, send time was 1400 for video). Both subsequent burns also played back choppy on the standalones. I decided it was because ffmpegX does variable bitrate XVCD, which none of my players can handle.
Outside of the VBR issue, the actual encodes themselves played back in Quicktime smoothly, with really crisp pictures, audio in sync at 48kHz and 44.1kHz sampling rates, and even the encoding speed was a bit faster over 0.0.2.
ffmpegX 0.0.9y-L for Mac OSX 10.7 "Lion" released
By major in forum ffmpegX general discussionReplies: 10Last Post: 29th Jan 2012, 04:27 -
Avast 5 Released...
By Poppa_Meth in forum ComputerReplies: 11Last Post: 29th Jan 2010, 15:48 -
Firefox 3.5.2 released
By pepegot1 in forum ComputerReplies: 7Last Post: 4th Aug 2009, 11:38 -
AV Linux 2.0 Released!
By GMaq in forum LinuxReplies: 7Last Post: 21st May 2009, 08:51 -
ffmpegX 0.0.9y released
By major in forum ffmpegX general discussionReplies: 12Last Post: 28th Nov 2008, 02:39
