I have some old Mpeg1 streams that I want to put on a dvd. I know that Mpeg1 at 352x240 is a supported dvd format but I have no idea about the supported audio format. The audio on the VCD is Mpeg1-II audio but the Dvd Demystified faq says that at least one audio stream needs to be in AC3 format (on a dvd.) Is that just for Mpeg2 video streams or for Mpeg1 video streams as well? I know my player will play them either way but I want to make these dvd's standard so that all players will be able to play them. I just want to make sure before I go and convert all the audio streams to AC3.
Thanks.
Dvd Demystified -- hmm dont know where they got that info because it is wrong -- you dont need 1 stream of ac3 .. you dont need any audio at all in fact but pcm or mpeg.audio or dts only will work also ..
for mpeg1 on a dvd -- exactly the same hold true .. -
I believe that what "the book" means, is at least one track has to have a standard audio format, be it AC3, LPCM or MPA (MPG1-Layer II). It cannot be entirely DTS or SDDS or other specialized audio tracks.
But, hey, I'm probably just like the rest of you... I don't have access to the real DVD spec.
As for Lance's original question, there is no specific audio requirement for MPEG1 video, except that the maximum audio rate is 384kbps. -
the whole specs are in 3 books - which yes , i do have a copy of .... but a lot of the specs are on-line also - this is a very good resource:
http://www.discusa.com/dvd/dvdspecs/dvdspec.htm
i have seen wrong specifications on many sites though ...
remuxing mpeg1 audio to mpeg2
By ChaosOrb in forum Newbie / General discussionsReplies: 3Last Post: 9th Sep 2009, 14:25 -
AC3 and mpeg1 audio
By izzykatz in forum Newbie / General discussionsReplies: 6Last Post: 14th Feb 2009, 11:39 -
DVD Audio format mismatch?
By Scally in forum Authoring (DVD)Replies: 4Last Post: 17th Jan 2008, 08:07 -
Audio conversion format for DVD
By supernano in forum AudioReplies: 1Last Post: 27th Aug 2007, 16:04 -
Video with 2 Audio Streams TO mpeg1 with 1 audio stream
By Xenogear900 in forum Newbie / General discussionsReplies: 1Last Post: 5th Aug 2007, 19:00
