Question for the board: I'm using TMPGEnc to encode Spiderman from avi to mpg. After it was finished, I played it back and after the first 15 seconds, there was no audio. I tried it again using the latest version of Tmpgenc and still the same thing. Is there something I'm doing wrong that's causing the audio to dissappear after such a short time? Should I rip the audio separately with Virtual Dub and try again? Any help is always appreciated. Thanks!
Yes, take the audio with Virtual Dub, and multiplex it your original file when you encode it to your SVCD file.
Hello. -
I had similar problem earlier ... go to option and then environment setting on TMPEG ... then go to VFPAI Plug-In .. set Direct show to a higher priority by right clicking on it ...
that solved my problem .. hope it helps
TMPGEnc Video Master Works audio problem creating bd25
By necron99 in forum Video ConversionReplies: 0Last Post: 29th Apr 2012, 19:52 -
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 06:36 -
TMPGenc Audio Problem
By Iwan2learn in forum Authoring (DVD)Replies: 5Last Post: 13th May 2009, 09:27 -
Audio Problem using AVISynth and TMPGEnc Xpress
By 1980sumthin in forum Video ConversionReplies: 10Last Post: 27th Jan 2009, 05:27 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41
