i was wondering if u can burn a dvd to dvd with a dvd burner without having to rip the dvd. I mean copy to copy. To copy from a dvd rom to a dvd burner like u can do it with a regular cd burner copy to copy.
The general rule is no you can't, however if the original DVD is NOT Copy protected and is under 4.7 GB then yes you can.......................
Aloha
Bud -
I'v had dvds that i didn't kno if they were copyrighted. I have some dvds that u can record to tape and itll come out clear but then there are some dvds that after u record them, the picture is messed up a little bit with this big line going through the middle. So does that mean that the dvd i recorded that came out clear isnt copyrighted or wat. Does the dvd that u r trying to burn show on a dvd rom how big is it, because i heard if its dual layer its too big.
So everything is good in the dvd burning software, does it say copy to copy like in the cd burning software.
