AAAAHHHAHAhHAHhaa
OKe i just want know who uses tmpgence and doesnt has any problems with it
and uses dvd template or encoding to dvd mpeg 2
what are your settings
I rarely have issues with TMPGEnc. I use the delivered DVD template, and occasionally modify it for higher bitrates. I consistently produce high-quality MPEG2, DVD-compliant video. My source is usually DV, either in an AVI or frame-served (only then do I occasionally have troubles, but its with the frameserver, not TMPGEnc). Other video codec sources, Quicktime, DivX, etc. work for me too.
Are you successfully producing an MPEG2 file that you can play on the PC? Is it not importing into a DVD authoring program? -
I'm not sure if you're in a PAL or NTSC part of the world, but it could be you're encoding with the template for the opposite system and your TV or DVD player isn't able to convert.
Problem With TMPGEnc
By Halibut72 in forum Video ConversionReplies: 2Last Post: 1st Oct 2008, 11:38 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
tmpgenc 2.5 plus problem
By DSLGuy in forum Video ConversionReplies: 1Last Post: 3rd Apr 2008, 14:38 -
TMPGEnc Problem
By djkevyb in forum Newbie / General discussionsReplies: 3Last Post: 27th Sep 2007, 15:46 -
TMPGEnc Problem !!!!!!!!!!!!!
By homantam in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2007, 17:56
