I'm kinda new to capturing, so here's the situtation.
Under the compression options for the Huffy codec...
Predict left / Predict gradient / Predict median
'Predict median' being the best compression, but I lose frames, and less frames using 'Predict gradient'. But when I use 'Predict left', I rarely lose any frames.
My main question is if I continue to use 'Predict left' as my compression method, will there be any degrade in the QUALITY of the capture versus using 'Predict gradient' or 'Predict median'? Or will my filesize just be larger only if I chose to continue using 'Predict left' ?
Hopefully my question isn't confusing to understand..
Thanks for any help.
In general, this settings will NOT affect picture quality. It always preserves the original image, bit for bit.
"Predict left" is fastest because it's the simplest technique. The "predict median" method is slower because it's a more sophisticated technique, but that sophistication yields better compression.
Which Mpeg2 compression codec?
By yugurya in forum EditingReplies: 6Last Post: 20th Jan 2012, 00:35 -
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 07:45 -
Huffy codec and field threshold
By TaranScorp in forum Capturing and VCRReplies: 7Last Post: 5th May 2011, 13:56 -
Compression Settings General
By oc6088 in forum Video ConversionReplies: 13Last Post: 7th Oct 2009, 21:14 -
codec video compression?
By coperta in forum MacReplies: 12Last Post: 9th Jan 2008, 10:28
