Hi
Does anyone know of somewhere I can obtain SCVD templates for TMPEnc. I have read lots of peoples opinions on the best settings for SVCD but has anyone created templates u can put in the TMPGEnc folder and select from the project wizard. Am I being dumb enquiring if this is possible??
Also could people please post their views on ........
CQ v CBR v VBR
Many Thanks
Fozzee
Results 1 to 14 of 14
The answer is in the main page here: http://www.kvcd.netOriginally Posted by Fozzee
And the FAQ here: http://www.kvcd.net/forum/viewtopic.php?t=68
-kwagKVCD.Net - Advanced Video Conversion
http://www.kvcd.net -
if you are looking for the standard templates, they are allready included in the tmpgenc directory... If they are not there, you may just need to re download tmpgenc. Tmpgenc comes with 3 standard svcd templates, NTSC, NTSC Film, and PAL. No offence to the creators of these templates, but the ones mentioned above are not standard svcd.
Hi
Thanks for the advice.
I suppose this takes us to part 2 of my question....
If I do use the SVCD Pal template in TMPGEnc what other settings do I use??
CQ????
VBR????
CBR?????
Cheers
Fozz -
cbr (constant bitrate) is by far the fastest, but it also uses up the disk faster. the bitrate allways remains at the same rate.
both cq and vbr are variable bitrate. cq (constant quality) works with only one pass, and yields good quality, but the file size is very unpredictable. it could be very large or very small...just depends on the source material.
vbr 2 pass(variable bit rate) takes twice as long since it it 2 pass. The first pass analyzes the video, then the second pass actually encodes. vbr is very predictable concerning file sizes. Once you calculate the average bitrate, then tmpgenc will automatically raise and lower the bitrate as needed (fast motion requires more bitrate to look right, whereas low motion does not need as much).
My personal pick is vbr, imho -
Hi
I was following you nicely Liquid until the last sentence LOL. I assume (maybe wrongly u were refering to the normal,high quality, etc setting???
If u were which do u use ?? If u weren't I'm lost
Fozz -
im sorry
my personal pick is vbr, (in my humble opinion)
as to motion search, i usually leave it on high -
Sorry Liquid
Not wishing to be picky (as your help is much appreciated) but...
When u say leave it on high you mean.....
1) High Quality(slow)
2) Highest Quality(very slow)
3) Motion Estimate Search(fast)
Sorry for not being on your wavelength.
Cheers
Fozz -
normally i leave it on Highest Quality....its not "very slow" as it really says
Cheers M8ty
I have just tried VBR it takes ages doesn't LOL
Is it really that much different than CBR??
What things do you encode on this method?
DVD Rips??
TV Capture??
DIVX ??
Cheers
Fozzee -
I do pick 2-pass VBR for myself. Well, i'm picky *LOL*, so i sacrifice time and file size to acheive best quality, anyway CDr are durt cheap and is not a limitating factor!
It takes about 14 hours for a typical 45min TV show episode at 1850 biterate and fit on a 700Mb CD, just leave your machine run overnight, it's not a big deal.
Hi
I'm usually downloading overnight will this make any difference to the encoding process?? I use Direct Connect.
Cheers
Fozzee
2 Questions regarding Templates for DVDs
By eduard879 in forum Authoring (DVD)Replies: 1Last Post: 9th Mar 2011, 08:01 -
DVD Cover Templates !
By MLOR in forum MediaReplies: 8Last Post: 23rd Jun 2010, 04:20 -
FairUse conversion templates
By herbapou in forum DVD RippingReplies: 1Last Post: 9th Mar 2009, 08:27 -
Tmpgenc Xpress 4 : any PS3 templates?
By lapino in forum Video ConversionReplies: 0Last Post: 12th Mar 2008, 08:34 -
DVD templates
By anfield7 in forum Newbie / General discussionsReplies: 2Last Post: 3rd Dec 2007, 01:16
