How long should smartripper take to rip a dvd (The spy who Sha**ed) me?
Im using a 2000xp athlon and pioneer 104 dvd reader/writer.
Its been going for about 10 hours and is only 40% done, is that right?
Results 1 to 10 of 10
Cheers
Jaffa -
Should not take that long.
Are you unlocking the drive by playing the actual movie for a couple of minutes before starting smart-ripper ?
dlb. -
no, am i supposed to do that, Its my first time.
If i start it playing my dvd will set itself to region 2 wont it?Cheers
Jaffa -
Ripping a movie with a different region to that of you're dvd-rom can cause problems. Try DvdDecrypter or Dvd2Svcd.
You could unlock the drive by playing another DVD first, ie one for the correct region which you are in (I assume you use region 1 ?), then quit the player program.
Swap disk's then start smartripper.
Not sure if it'll make any difference, but it could be worth a try.
Also, have you installed the Adaptec ASPI layer ?, This made a difference on my system. -
My Pioneer 114 DVD drive takes about 35 mins on average to rip a 1hr 45min film, and I'm using a PIII 850Mhz CPU
Panther
All say Grrrrrrrrrr...................... -
I only got the dvd writer yesterday so nothing has been played on it yet, if i try to play a dvd it asks me to set the region (Im region 2). If i do that will i only be able to rip region 2 dvd's.
I dont need the dvd for watching purposes.Cheers
Jaffa -
What OS are you using? Windows XP can switch off DMA on Atapi drives if if gets minor read errors. This can reduce the read rate drastically.
If you try DvdDecrypter with a disc of a different region it will warn you and use a different rip method.
Worth a try. -
i use win xp pro i got athlon 1000mhz with 780ish meg ram and a lg dvd reader and it takes me no longer than 20 mins to read any movie with smartripper. longest was lord of the rings which took me 17 mins
sheesh -
Thanx everyone 4 yr replies, it seems to work now i told it im region 2
Cheers
Jaffa
BD Rip worked only once, now can't rip BDs successfully
By thestrangebrew in forum Blu-ray RippingReplies: 2Last Post: 1st Apr 2012, 08:30 -
How to fix incorrect time? MKV rip displays as 14+ hrs long in all players
By elcoyoteloco in forum Video ConversionReplies: 2Last Post: 6th Feb 2011, 12:11 -
How Long Shoud It Take to Rip Blue Ray?
By wulf109 in forum Blu-ray RippingReplies: 3Last Post: 23rd Oct 2010, 01:04 -
how long
By Tobias0815 in forum FeedbackReplies: 3Last Post: 1st Jul 2008, 19:08 -
my rip spec hell - from a ts. folder to rip specs - how?
By marinebc11 in forum MacReplies: 5Last Post: 26th Nov 2007, 20:28
