Ok I used DVD2SVCD to convert a dvd movie(Deuces Wild) to 3 cue files. Ok I burned the three on to discs and played them and it looked great. No mess ups or anything. Problem I put the movie in today and usually the same spots everytime but there will be like pixelization from time to time. But then I took it out and stuck it back in and it didn't do it. Then tried putting it in again and it did it again. How can i get rid of the pixelization effect all together. Is there any way? I don't mind using 3 or 4 cds for one movie but I do mind the pixelization. I would like to have it as close to dvd quality as possible.
Oh by the way i used 3 cds to do this and the movie was 138 min long
used 43 min on 800 mb so what bitrate was that should i have used less minutes than that the cds came out like this 2 were like 700mb and one was 236mb or something. anyway there was still some pixeliazation. Does pixelization come from the ripping process or the burning process. Because I have mad svcd's from image files that are perfect and 10 min later i will burn from the same image file and have pixelization????
Can anyone help please -
If you want to get as close as possible to dvd quality on 3cd for 138 min. movie then i recommend using an average bitrate of about 2100. This will get you very close to dvd and fit your movie on 3cd. (Its what I do, so I know the results). If you using DVD2SVCD (I just decided to give this frontend a shot), then in the bitrate section adjust it so that you fit about 45 min. per cd. I have it setup like this:
0 - 46min. --> 1 CD (800mb) ---> ? - 2142
46 - 91 min. --> 2 CD (800mb) --> 4520 - 2166
91 - 136 min. --> 3 CD (800mb) --> 3368 - 2175
136 - 181min. --> 4 CD (800mb) --> 2979 - 2179
181 - 226min. --> 5 CD (800mb) --> 2783 - 2181
226 - 9999min. --> 6 CD (800mb) --> 2665 - ?
Most movies are either around 90min. or 120min. Hope this works out for you.PlaiBoi -
hey i encoded with those settings and i don't know about you but i think it sucks. Yes it is viewable. But there are still pixelization there and I don't want that. I did a dvd2svcd at these setting and its beautiful no pixelization at all. Used 3 cds for 132 min dvd
0-43
43-86
86-129
so forth
Hey one question though if the movie was 132 how was I able to fit it on 129 min on 3 cd's?????????????????????? -
if you want best quality with 4 speed dvd player (most standalones, but check !)
Use CCE...VBR Min 2500-Avr 3500 Max 4500 for video.
If your player does support it, it fits 30 minutes on a 800 mb cd.
I tried converting a dvd with this and didn't see the difference...if you don't zoom though
TMPG should be almost as good when doing a multipass with these settings, if free and easyer to come by.
good luck. -
Did you look at it on your computer or on your dvd player? It makes a BIG differance. Wierd, cuz i dont see pixelation, and im huge on quality. I dont think changing the amount to fit on one cd by 3 min. would increase the quality by as much as you describe.hey i encoded with those settings and i don't know about you but i think it sucks. Yes it is viewable. But there are still pixelization there and I don't want that. I did a dvd2svcd at these setting and its beautiful no pixelization at all. Used 3 cds for 132 min dvdPlaiBoi
DIVX3 on Danelec so easy hdmi ***** newbie question
By fraguil in forum Video ConversionReplies: 2Last Post: 6th Sep 2011, 04:56 -
You Tube Question... (should be easy)
By greenstrat in forum Video Streaming DownloadingReplies: 1Last Post: 20th Jul 2009, 22:47 -
Newbie, advise for easy 1 step backup of dvds
By mbogda in forum Newbie / General discussionsReplies: 5Last Post: 4th Sep 2008, 13:18 -
Newbie Roxio easy cd and dvd burning question.
By mmmipa in forum Newbie / General discussionsReplies: 8Last Post: 24th Nov 2007, 21:31 -
Newbie looking for easy guides, links, and general information
By TazDevil in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2007, 11:53
