hrmmm... a quick question...
i have a 256meg memory stick lying around... and i have this old computer that has slots that take a max of 128megs each....
so... i was just wondering what would happen if i put that stick in... ^^;;
i'd be happy if the mobo sees and uses only 128 megs of the stick... but also don't wanna screw the computer up by actually putting it in before someone knows anything about this... :P
thanks!! ^_^
It might work the way you want, thats what my moms computer did... or it might not. But its unlikely that the stick itself will damage anything, its worth a try.
Sometimes you miss a slot then put it on the next, your Motherboard manual should tell you what works. If it says 128Mb Max, then its not going to work..
0 = 128
1 = 128
or
0 = empty
1 = 256
They should be the same speed, type to work
best method(s) for imaging a hdd, quickly to mem sticks/cards?
By vhelp in forum ComputerReplies: 14Last Post: 12th Sep 2011, 18:52 -
HIS 9600pro ATI 128Mb AGP - driver installation ???
By blinky88 in forum ComputerReplies: 6Last Post: 22nd Sep 2009, 05:52 -
Getting a movie on 2 x 256mb SD card
By NeWcS in forum Video ConversionReplies: 1Last Post: 8th May 2008, 00:48 -
Compaq PC133U-333-542-A 256MB, SYNCH, 133MHZ, CL3?
By rkr1958 in forum ComputerReplies: 3Last Post: 21st Oct 2007, 19:54 -
Mem stick, is there such a thing as a router for it ?
By vhelp in forum ComputerReplies: 2Last Post: 6th Jul 2007, 04:20
