all i want to do is burn my divx movies onto 1 cd each movie, i dont wanna split the movies up into 2 cds, all of the movies are around 1 hour 30 minutes, and they are all 720 mbs and lower, is it possible for me to burn one of my movies fully onto a 80minute 700mb cdrw????? i tryed usin the help guide here for settin a movie to 1 cd but my bitrate was lowered to like 142 or sumtin crap like that, im just really confused and need answers ,, pleeease help me
try King Vipers SVCD template. If the Divx file could fit on a CD, then this template will make an SVCD that'll most likely fit on one CD as well. I used to use it all the time and it worked great. There are also the KVCD stuff, but they are XVCDs.
Simple Question re Premiere CS5
By jkholmes in forum Newbie / General discussionsReplies: 10Last Post: 3rd Mar 2011, 22:50 -
AviAddXSubs simple question (hopefully!)
By vladman2nd in forum SubtitleReplies: 1Last Post: 8th Jul 2008, 02:01 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 22:10 -
Embarassingly simple capture question
By eclipse95 in forum Capturing and VCRReplies: 5Last Post: 16th Nov 2007, 14:12 -
another simple question about FCE and iDVD... =)
By ednarophati in forum MacReplies: 1Last Post: 31st Jul 2007, 11:15
