  1. whats the best way to convert an asf movie to a mpeg movie?
  2. Compress your asf to vcd with tmpgenc :
    there ar two lines :
    video : example.asf
    audio : example.asf
    target file : example.mpg
    in the line of audio : delete everything
    tmpegenc will compress your video in silence .
    then use Windows media encoder SDK
    -select de ASF and convert the audio of the video to wav
    . use CD quality to preserve the shit of quality of the sound . hehe .
    then compress this to layer II ,44100khz 224kbits
    and multiplex , that's all.
    you can convert the wav first and put this wav in the line of audio location , there's no problem with that .
    good luck , and sorry , but i'm from venezuela & my english is not to good.
  3. in tmpgenc when i try to create a mpeg, even if im using an mpeg as the video source, it says it cannot be created, whats wrong?
