At the moment we have a mishmash of recordable DVD formats available to us everyday consumers. I've read various papers and propaganda from the different camps ( the + and the - ) and have come to the conclusion that there is no reason why a DVD-R/RW couldn't write to a +R/RW disk or vice versa.
Before everyone starts to argue about this let me say that this is a THEORETICAL posibility. Both types of disk spin in the same direction, have the same capacity and use the same wavelength laser (650 nanometer) to burn the information. The difference is in the firmware and logical format of the disks.
Could it therefore be possible that all those people out there with flash upgradeable DVD burners, one day be able to download an upgrade to enable them to use whatever disk they liked? This way the clear winner will be the format that has the most compatability with standalone players.
I don't care what anyone says or what companies claim is better. I want to be able to make my own choice without needing to purchace or otherwise gain access to seperate pieces of hardware that essentially do the same thing. All the + and - bickering will only end up hurting the percentage of consumers that bought into the format that will eventually lose.
I'm not too sure if anyone else has made a post like this one....If they have...sorry for the duplication.![]()
It may be technically possible but probably not politically.
I wouldn't hold my breath.
Regards.Michael Tam
w: Morsels of Evidence -
I agree that the probability of Pioneer or HP releasing an all-in-one firmware patch is next to nill.....however I have seen a bit of a firmware hacking culture with DVD rom drives making them region free and other such things.....It could be possible to hack the firmware of various drives to make them "+R compatable" or something given the hardware specs of a burner (chips used, API's etc). Theoretically all it needs to know is how to read the disk and how it is formatted...
I'm not going to be holding my breath for anything though
It is unlikely that existing drives contain the hardware necessary to write to the other media type.
Such a drive could probably be created, but I doubt it would be without some big breakthough of co-operation between the two commercial camps.
Regards.Michael Tam
Not possible with Existing drives. Case in point the First Generation DVD+RW drive. It had to have additional H/W to write reliably to +R. Also, +R/RW has a higher Wobble groove thus you would need additional H/W to be able to detect it and write reliably. These are just two limitations that come to my mind. I am sure there are others. BTW, DVD+R and DVD-R do not have the same size limit. You can get about 8MB more on a DVD-R disk. Of course 8MB is not much in the big picture.
RG
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 20:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 19:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 14:42 -
Dropsies-What's the worst you've dropped a hard drive onto a hard surface
By Seeker47 in forum ComputerReplies: 6Last Post: 11th Jun 2008, 13:53 -
hard disc 1 died, hard disk 2 won't boot, halp!
By Yoroshiku in forum ComputerReplies: 6Last Post: 30th Oct 2007, 14:48
