Hey - I am trying to compile a project of 22 video clips in SpruceUp to a title set. the prob is whenever I get to 51% of the compiling I get an error saying invalid video input. I had to convert all my mpgs at the same time to mpeg2 through tempg. So I cant really figure out how to fix this, any help would be appreciated.
SpruceUp Can be picky when it comes to .mpg files. I get the same error from time to time also, it seems to have something to do with audio problems. Try reloading the files into MPEG tools, (Merge and Cut), and try cutting off a frame or two at the beginning and at the end of the video (save the original just in case). If it gives some kind of error warning, just click on the Correct button and the Run it. Hope this helps.
ffmpeg Patch - Compile Request
By Ruler2112 in forum Video ConversionReplies: 5Last Post: 14th Oct 2009, 01:39 -
DVDLab Pro 2 compile issues
By milofhead in forum Authoring (DVD)Replies: 3Last Post: 27th Oct 2008, 23:25 -
How to compile libmatroska and libebml
By Maikeru-sama in forum ProgrammingReplies: 1Last Post: 23rd Jun 2008, 20:59 -
Anyone know how to compile this program?
By Milardo in forum LinuxReplies: 5Last Post: 21st Jun 2008, 00:10 -
Noob here, Compile Dvd problem!
By dbgt in forum Authoring (DVD)Replies: 3Last Post: 8th May 2008, 18:08
