Hi,
Im getting rid of an ATI TV wonder VE... trying to find something better i have this in mind:
http://www.aver.com/products/tvstudio01.html
Aver TV studio
I found a review of it
http://www.cheapgeek.net/reviews/avermedia_avertv.shtml
i need to know if itll cap in AVI format at 640x480... this is important to me... my specs are::
AMD Athlon XP 1600+
5400 40 GB HD (probably gonna get a new on of these too)
512MB RAM
Geforce 2
Results 1 to 11 of 11
Hi
I have had this card a week. I may not be the best person to advise but this may help. The software that comes with it captures mpeg1/2. I transfered to PowerVCR to do my capturing as it has lots of different profiles (VCD. SVCD etc) and this produces good quality MPEG 1/2. I then encode using TMPEnc and get good results. I have tried capturing AVI with VirtualDub and IUVcr and it does capture OK. Strangely tho the MPegs I do using PowerVCR have a much smoother picture. Hope this helps but as I do not know why u want to capture AVI it may not
Cheers
Fozzee
Athlon XP 1700+
512mb Sdram
Geforce2 MX 400 64mb
AverTV Studio -
yes but does it do AVI at 640x480 with minimal frame loss. although i may look into this card more i capture avi to convert to mpg in tmpg enc but if it does good enough mpeg2 caps to convert down... i may go for it.. still one thing i need to konw thats not really for this forum...
Well I have had that card for about 6 months now It does 640x480 Mpeg 2 fine with it's own software but for some reason I can not select 640*480 in Virtual Dub with Windows XP
takaznik, mate youve got a geforce2 card and obviously ure agp slot is used!
So the best card available believe me Is the All in wonder Radeon 32Mb Sdram PCI version. Its the best combination you can have with ure Geforce card. It does all the res olutions u'll want. BUt, only problem is ATI stopped now making them since The new radeon cards came out,these new cards are all agp though.
So go for it if u can find one available!!!! -
the thing is i dont have an AGP slot my mobo sucks... im also trying to stay away from ati... but if i can find a radeon AIW pci i might get it... time to check ebay...
I would recommend you getting the Hauppauge PVR 250, I have this card and does all the capture settings right up to dvd quality. I have had no problems with this card and would highly recommend anyone to get this card as its quality and easy of use is remarkable.
Alam -
Not sure why people are recommending the PVR250 when your requirement is avi capture at 640x480. The avertv studio will do that just fine. In fact if you don't need the remote control or the FM tuner the avertv stereo will do fine too and it's only $50.
lusid who need AVI when you can do REALtime MPEG HW encoding at 720x480(NTSC) or 576(PAL) all way to 12MBit/sec and saving hour's of re-encode and lots of disk space to boot plus it come with ever thing need to make VCD/SVCD/DVD and come with the best Authoring Software you can get Ulead DVD MovieFactory all you need is the CD/DVD Burner to make the magic happing hehe.
Which is better - usb stick vhs cap or hd-pvr cap + convert for vhs to dvd?
By yoda313 in forum Capturing and VCRReplies: 22Last Post: 22nd Dec 2011, 21:13 -
Opinions On Which Monitor to Buy?
By RKelly in forum ComputerReplies: 4Last Post: 17th Jan 2010, 15:10 -
Cap Card Editing Issue?
By Evas1on in forum Capturing and VCRReplies: 7Last Post: 7th Jan 2010, 12:25 -
OK Gonna buy the HD palmcorder.....now what?
By gom in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 20th Jun 2009, 14:27 -
Suggestions On Buying Cap Card
By x420x Lovin in forum Capturing and VCRReplies: 4Last Post: 23rd Mar 2009, 03:14
