Is it normal to be dropping 23 frames in the first 12min. of capturing? This is my first time trying to capture video.
I am interested too to find out what is consider acceptable loss as today I was using Virtualdub for the first time and I noticed I lost more frames than I would have liked. I rebooted and it was much better.
But from some info I saw it said that sometimes frames need to be lost to keep the sound in sync so that could be the reason.Not only am I perfect but I'm Canadian too! -
Frame loss should not be acceptable at all, 1 in 1000 is not so bad
but if it needs to drop frames to keep up with the audio, then its not going to be very good is it ?
if that capture is then put on a VCD, or used later to convert, that's when all the problems start, playback of these files will always look good, even if lots of frames were dropped.
I have a very basic capture card, its so basic it has HMV stamped on it
however when capturing at VCD .mpg it never drops a single frame. Capturing at the limit of your card/pc could be causing this problem.
If the frame loss is at the start, it could be the system settling down to the capture, so as long as there is no other frame loss, that should be just fine, just start the capture a little earlier.
Other info
http://www.virtualdub.org/docs_capture -
Thanks I think I got it. It would drop 3 frames when I started and a couple more when I cut out the commercials on the tape. I'm capturing some old Beavis and Butt-Heads that I recorded a long time ago.
Are these lines normal?
By Abas-Avara in forum Newbie / General discussionsReplies: 12Last Post: 18th Oct 2009, 12:41 -
Normal or not?
By alintatoc in forum ComputerReplies: 4Last Post: 25th Mar 2009, 01:36 -
Normal encoding
By mrgorgeous in forum ffmpegX general discussionReplies: 4Last Post: 5th Oct 2008, 18:42 -
vegas - is this normal?
By wingfan in forum Authoring (DVD)Replies: 9Last Post: 18th Jul 2008, 09:52 -
Is this normal for SUPER?
By ryphlex in forum Video ConversionReplies: 2Last Post: 17th Jul 2007, 15:27
