Is it my fault or the program's that there is sync problems when i convert dvd to mpeg or divx to mpeg? How can I fix this? Thanks in advance...JAT
Major- Here it is!
Welcome to Darwin!
/Volumes/ffmpegX_0.0.2/ffmpegX.app//Contents/Resources/ffmpeg -i /Users/jat/Desktop/STUFF/Name/DiVX/Name.avi -y -f mpeg -vcodec mpeg1video -map 0.0:0.0 -b 910.067290780142 -s 352x240 -g 12 -me epzs -qmin 1 -qmax 9 -benchmark -vcd -acodec mp2 -ab 128 -ar 48000 -ac 2 -map 0.1:0.1 /Users/jat/Desktop/STUFF/Name/VCD/Name.mpg; /Volumes/ffmpegX_0.0.2/ffmpegX.app//Contents/Resources/vcdgear -mpg2bin -toast /Users/jat/Desktop/STUFF/Name/VCD/Name.mpg /Users/jat/Desktop/STUFF/Name/VCD/Name.mpg.bin
[localhost:~] jat% /Volumes/ffmpegX_0.0.2/ffmpegX.app//Contents/Resources/ffmpeg -i /Users/jat/Desktop/STUFF/Name/DiVX/Name.avi -y -f mpeg -vcodec mpeg1video -map 0.0:0.0 -b 910.067290780142 -s 352x240 -g 12 -me epzs -qmin 1 -qmax 9 -benchmark -vcd -acodec mp2 -ab 128 -ar 48000 -ac 2 -map 0.1:0.1 /Users/jat/Desktop/STUFF/Name/VCD/Name.mpg; /Volumes/ffmpegX_0.0.2/ffmpegX.app//Contents/Resources/vcdgear -mpg2bin -toast /Users/jat/Desktop/STUFF/Name/VCD/Name.mpg /Users/jat/Desktop/STUFF/Name/VCD/Name.mpg.bin
Input #0, avi, from '/Users/jat/Desktop/STUFF/Name/DiVX/Name.avi':
Stream #0.0: Video: msmpeg4, 576x304, 23.98 fps, q=0-0
Stream #0.1: Audio: mp3, 48000 Hz, stereo, 141 kb/s
Output #0, mpeg, to '/Users/jat/Desktop/STUFF/Name/VCD/Name.mpg':
Stream #0.0: Video: mpeg1video, 352x240, 23.98 fps, q=1-9, 910 kb/s
Stream #0.1: Audio: mp2, 48000 Hz, stereo, 128 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Press [q] to stop encoding
run too long at 21 8e= 118930kB time=131.0 bitrate=7437.5kbits/s
error while decoding block: 21 x 8 (1)
Error at MB: 309
concealing errors
frame=134971 q= 4 size= 720576kB time=793.8 bitrate=7436.5kbits/s
bench: utime=8261.070s
VCDGear v1.6e build 082401 coded by Dracore (dracore@home.com)
MPEG file source --> /Users/jat/Desktop/STUFF/Name/VCD/Name.mpg
BIN image destination --> /Users/jat/Desktop/STUFF/Name/VCD/Name.mpg.bin
Conversion method --> mpg2bin
Track # Video Size Frame Rate Video BitRate Pack Size
1 352x240 NTSC 23.98 fps 910000 kbits/sec 2324 - ok
100% [00:00:00] Track 1 -> writing...
?file structure created.
completed. Track(s) written.
[localhost:~] jat%
-JAT -
Your settings are good. How much the audio is off sync, is it increasing off sync or constant along the movie, is it happening only on DVD player or also on Quicktime player, is your source in sync?
major-
the source is in sync. On quicktime it is always out of sync and on the dvd player is is MOSTLY out of sync except at the end. -JAT -
If you use 0.0.3 and "Split in 1 chunks" do you get the same result?
If you export the source to Quicktime MPEG4 is it in sync?
FFMpegX Audio problems
By Cowchan in forum Newbie / General discussionsReplies: 0Last Post: 11th Dec 2011, 11:00 -
Muxing problems with ffmpegx
By Themroc in forum Newbie / General discussionsReplies: 0Last Post: 5th May 2009, 20:49 -
Problems with ffmpegX
By KeepItSimple in forum MacReplies: 2Last Post: 5th Apr 2008, 21:46 -
single .vob in ffmpegX to h.264 (mencoder) .mp4 a/v sync issues
By jabroni5 in forum ffmpegX general discussionReplies: 15Last Post: 7th Jun 2007, 17:48 -
ffmpegx Problems! Help!
By The Sumerian in forum ffmpegX general discussionReplies: 4Last Post: 10th May 2007, 01:36
