i just bouhg the JVC xvs300bk dvd player model, and i am having a real hard time with the vcds and svcds. At first it worked fine, now everytime i put one in it says "now reading" and finally quits and won't play them. if anyone has the same troubles or any solutions i would really appreciate it
thank you all so much for your time![]()
Did you make the .mpg with TMPGEnc, and did you load a VCD template. Did you use high quality disks ?
i burned the image .cue file using nero, but the strange thing is that my vcds worked like right when i got the player, now all of the sudden they don't???
the vcds and svcds i have used are usually downloaded, i have made a few of my own with tmpeg, is there any file that will let me know if it's pal or ntsc or whatever, because i think it says that it has to be ntsc,
it still seems weird to me because my vcds played right when i got it, then i tested an svcd, i don't know if it was encoded wrong, but now it won't play either vcd or svcd.
thanks for everyones help, if anyone knows the solution to this mystery let me know
thanks! -
Yes the screen size
352X288 PAL 352x240 NTSC VCD
480x576 PAL 480x480 NTSC SVCD
Does your player play PAL ? if not then you must use NTSC
VCR Comparison: JVC SR-W5U vs JVC SR-V101US
By robjv1 in forum RestorationReplies: 18Last Post: 22nd Apr 2021, 03:36 -
JVC HM-HD30000U For Sale - JVC Refurbished!? What?! :)
By jbd5010 in forum Capturing and VCRReplies: 7Last Post: 22nd Jan 2011, 20:30 -
JVC SR-MV55US - Users with Experience with JVC Professional S-VHS/DVD Decks
By Anonymous4 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 21st Aug 2008, 15:23 -
Should I BUY the Canon HG10, JVC GZ HD7 or JVC GR HD1 ??????
By thecuban in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 27th Dec 2007, 12:40 -
TV Out Troubles.
By SE14man in forum Newbie / General discussionsReplies: 54Last Post: 11th Oct 2007, 16:55
