I am in the process of starting out in the Video aspects of computing. I have lots of experience in still photography and I am learning about Video everyday. Before I purchase a Capture/Editing/Authoring system, I tried a few things out by making a small movie using VideoImpressions, found in Roxio's "Easy Ceartor 5 CD." I realize that this is far from the best, but it is a starting point.
I copied some video clips, of varying quality, from the Web. Some played well on the computer and some were just lousy. I used TMPGenc to convert from AVI to MPEG's 1 & 2. I used CDRWIN(cue & bin) software to burn to make a VCD and a SVCD. I played them in my JVC DVD player and the video quality was terrible!! However, the still pictures were fine.
If you do the same with photos taken from the Web, at 72 dpi, and try to print them, you will get a less than good result, as 300 dpi is required.
Am I seeing a similar phenomenon with Video from the Web?
I plan to use an analog system, as I do not plan to purchase a digital VCR & Camcorder. How is the quality of Dazzle products & Pinnacle Systems Studio Deluxe in this regard? Remember, I talking analog inputs.
Your response will be greatly appreciated. If they produce videos like I made with video impressions, from the Web, that would not be satisfactory at all.
Thank you all
Let's make this simple. What is the video quality of a < $300.00 analog capture card?
Assume good VCR & Camcorder tapes. -
Also don't forget - garbage in = garbage out.
I use ATI AIW 8500 to capture video from VHS. Depending on the setting used on the camcorder (i.e. extended play or normal) has a huge effect on the quality of the captured file. MPEG2 captures, from VHS recorded in normal setting make for pretty good VCDs (I would make SVCDs but my DVD player does not support that format). On the other hand, MPEG2 videos, captured from VHS recorded in extended play look terrible. Also, the connection from your player to your capture device can effect video quality - Firewire connection is the best if your source supports it - my camcorder and VCR don't so I use SVIDEO.
Using DVD2AVI and TMPEG I convert the files to VCD and Nero to burn. -
Don't waste you time with Dazzle, I sent mine back after a week. I am now looking at getting Pinnacle's Studio Deluxe.
Brian -
Firewire -> capture with MS Movie Maker (Come with Win XP).
Encode to VCD with TMPGEnc -> Noise Reduction checked and double click on it to set all the parameters to full (might 2-3x the conversion time) + color correction (Gamma to 50, Red, Blue to ~80-120 depending on your source, good if your source is a below US$800 camcorder) -
Originally Posted by vcdfreak
help me improve the video quality of my game trailer with avs video editor
By DapperDave in forum Newbie / General discussionsReplies: 4Last Post: 24th Apr 2012, 01:06 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 19:23 -
Flash with high quality video (MP4 with H264 video and AAC audio)
By Baldrick in forum User guidesReplies: 49Last Post: 19th Mar 2010, 09:05 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 13:38 -
video quality to movie quality
By pitta1990 in forum Newbie / General discussionsReplies: 2Last Post: 24th Nov 2007, 23:31
