I downloaded a couple movies from kazaa in .avi. I converted them to mpg using tmpgenc. I used the soften block filter in tmpgence and converted them. I then viewed them before burning them with VCDEasy. They looked fine, but once I burnt them and played them on my TV dVD player I get a bunch of blocks of colors during scenes with lots of movement. Is there anything I can do to fix this. I use the generic mmc raw driver in VCDeasy and CD-RWs to burn with. I have been trying to figure how to do this on my own, but I've already wasted a bunch of CDs and could use some help. Thanks![]()
crap in = crap out. you have to have a good source. the only thing i can suggest is to encode your movie with a higher bitrate,but that is of course NO guarantee
If the artifacts are present on the AVI's there is very little you can do about it. The strength needed to blend one frame, could obliterate the next frame completely.
If the original AVI's don't have the problems, then it could well be things on your computer that can cause these problems, DirectShow priority not set high enough, Installing the SMR (Angel portion) is a cause of violet, pinkish colour. etc
Problem playing certain AVIs on standalone
By max6166 in forum Newbie / General discussionsReplies: 12Last Post: 20th Dec 2008, 22:32 -
Standalone recorded DVD playing in a Mac problem
By tigerdad in forum MacReplies: 4Last Post: 5th Aug 2008, 20:28 -
DVD playing in standalone player but not on PC
By Leo48 in forum Newbie / General discussionsReplies: 2Last Post: 28th Jun 2008, 09:35 -
DVD Extras Not Playing Back in Standalone
By SamNZDat in forum Newbie / General discussionsReplies: 2Last Post: 16th Nov 2007, 03:29 -
Problem with playing DVD in standalone player
By tngolfn in forum Newbie / General discussionsReplies: 2Last Post: 14th May 2007, 17:41
