  1. I captured a few series with PowerVCR in SVCD. Now I want to cut the advertisement and join the parts together. Normally I use the Tmpenc Tool for something like that, but the parts are in Constant bitrate and the tool I use can handle only VBR. When I use it, the sound and the movie are not syncronized after cuttin/joining. Who knows a tool which I can use (and please a simple one, not with thousends of possibilties )
    Thanxz for help
  2. You might try VCDcutter. It's in the TOOLS section on the left.
    BTW how do you like the results of PowerVCR? I've been meaning to try it out.
  3. Hi, I will try it out. PowerVCR is the best program i used for something like that...Its very easy to handle and you can really use it like a normal VCR (sheduling)...I can`t say anything to the quality `cause I´ve no comparison...But I think it`s Ok, because you donnot have to have so much space on your HDD...
  4. maybe 'Camel's MPEG Join' could do the trick also
    oO ELVIS Oo
  5. Where can I get this tool???
