when i am playing the movie on my dvd player it often stutters. it doesnt completely freeze but it is a bit shaky at times. is there a way to fix this? either before i burn it or after...
Where did you get the movie from?, was it an AVI you used to burn?, did you convert it with TMPGEnc using a VCD template?. Did you use good quality disks ?
hi i have the same problem and im just givin my word in
i dont think the quality of cds matter that much... my stand-alone vcd player could play pirated vcds before... and i dont think ppl who make those pirated vcds would make them out of high quality cds.. i had no problem before.. but now it stutters when i try to play my own burned vcds... even when i tried to watch an official vcd it still stutters... so my clue would be that its the player problem... im not sure.. but i think you should get it checked.. as i will with mine
in the meantime try your vcds on a friend's vcd player or somethin...dont waste your time and cds burnin more cds to try to see if they work or not -
it was an avi and i did use TMPGEnc but it still stutters, computers have anti-freeze programs...thats probably why since dvd/vcd players dont
OK, did you scan for junk frames in Vdub first, did you load a VCD template in TMPGEnc
Video > Scan video stream for errors
See my other posts on "vdub-mp3-freeze.exe"
Sound is stuttering
By GeordieDave in forum Newbie / General discussionsReplies: 7Last Post: 19th Apr 2011, 18:21 -
Video stuttering.
By reyerd in forum Software PlayingReplies: 12Last Post: 27th Mar 2011, 05:07 -
Stuttering mpeg
By GerryJ in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 3rd Feb 2010, 21:23 -
Skipping - stuttering
By bryankendall in forum DVD & Blu-ray PlayersReplies: 3Last Post: 17th Jan 2010, 12:55 -
Stuttering on PS3
By wjfisk in forum DVD RippingReplies: 10Last Post: 7th Apr 2009, 14:15
