I'm trying to burn a CVD on to a DVD-R with toast. Boes anyone know how to do this on Mac OSX. I have DVDSP if its neaded.
Thanks, Arri
DVD Studio Pro requires demultiplexed (aka elementary) streams in order to import video, audio and stills into your project. The video and audio must have been previously encoded to DVD specifications also. The biggest problem you might encounter is the video was encoded without closed GOPs, or too large of a GOP.
If this is your first time using DVDSP (or one of the first times), you'll find its not very intuitive in terms of the natural flow of steps to make a project work. Spend some time reading the manual. Even though it too isnt done very well, you'll save yourself a week or more of frustration by looking at it. -
Thanks for the input AntnyMD.
Yesterday I figered out the settings in MediaPipe so it would work in DVDSP. I used the some of the same settings if I was decoding a ripped DVD mpeg2 to mpeg2 to a lower bit rate for for DVDSP. I ajusted the scale and blackbourders. The same CVD works great on CD-R and DVD.
CVD/DVD For 16:9 Pipline Design (Will work in DVDSP)
File Browser
File Streamer
MPEG Decoder
Colour Conversion
Scaler
Height 360
Width 352
Black Borders
bottom 60
left 0
right 0
top 60
Frame Rate Changer
Duration 1001
Soft Change false
Timebase 24000
MPEG Encoder
mpeg2enc -v 0 -f 8 -a 3 -F 1 -p -b 2520 -I 0 -n n
ppmtoy4m -v 0 -F 24000:1001 -S 420_mpeg2
Anyone mirrored or saved OGT/CVD subbed test images?
By zinchronized in forum Newbie / General discussionsReplies: 5Last Post: 11th Aug 2010, 22:46 -
Looking for test SVCD images with CVD/OGT subs
By zinchronized in forum Authoring (VCD/SVCD)Replies: 0Last Post: 11th Aug 2010, 07:55 -
Quality loss VHS > CVD, DVD
By rglmrj in forum Video ConversionReplies: 15Last Post: 1st Jun 2007, 12:13
