    Jul 2002
    Lombard, IL.
    The ATI AIW comes with a cable with 4 inlets. The S-video in and the 2 sound in. Has anybody connected to ATI's sound plugs and captured instead of into the sound card? I have a Creative SoundBlaster AudioPCI 64V that doesn't have the 2 lines in for stereo. So wouldn't it be better to use the ATI's stereo lines in?
    Apr 2001
    ...I hope I'm not taking too much of a leap here...
    Are you POSITIVE that those plug's aren't Composite video? Or, Digital Audio Out?
    The AIW works via pass-thru, no other way. There is the convenient input patch dongle (S-Video, Composite, L-Audio, R-Audio, on one socket), but that goes into the AIW card, then right back out thru the pass-thru which goes into your LINE-IN on your sound card. This is the small, black plug that's stereo (just like a headphone jack).
    The only audio INPUT I know, is the one located on the large patch dongle.
    Aug 2002
    stockton,ca
    yes I have a soundblaster live hooked up int to ati aiw card
  4. As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
    Aug 2002
    stockton,ca
    go to the book. connect cd audo in (on sound card) to (cd out)
    onati card.works for me. page51
