Problems with tmpgec
i tried every template of tmpgen
i tried the link http://pwp.netcabo.pt/0165394101/TMPGEnc_Template.html
stil i got the shocking flickering end results
on pc and on dvd r
i got a p3
650 mhz
256mb
free hd 14 g where the ecode is
and free 7 g where the movie is encode from
[/url]
whow, whow, hold your horse there...
Size: 720x576 (for PAL) or 720x480 (for NTSC)
what are you trying to do? VCD, SVCD, or DVD? -
this is must be the most stupid question I ever asked...
you got a DVD burner right? -
Ok, now we're talking... ha..ha..
your DVD burner should come with burning software, don't know about yours but mine (MyDVD which is crap) all I have to do is just drop the file and it start do it's own magic, as long as it's a 720x480, Mpeg-2, 48Khz @ 384stream.
Other than that, even if you try to drop Mpeg-1, it still can do but it just takes a little longer to reencode.
Anyway, PIII 650 might just don't cut to play home made 720x480 at 29.97fps. Try master VCD or SVCD on CD-RW first then move up to DVD. Or at least try making a DVD with low constant bitrate, yup, it'll come out crap but as long as it comes out, then go from there. Bottom line, "constant bitrate" is a key to your problems.
Multiple Files & Resolutions In Tempgenc Xpress 4
By TufrThanu in forum Video ConversionReplies: 0Last Post: 9th Aug 2009, 15:21 -
error while burning DVD DL using tempgenc dvd author
By rgpai9972 in forum Authoring (DVD)Replies: 2Last Post: 2nd Jun 2009, 22:15 -
tempgenc authoring works 4 - can I save the edited clips?
By yvonne_1980 in forum Authoring (DVD)Replies: 2Last Post: 24th Mar 2009, 06:59 -
Tempgenc DVD Author small file
By EPLindblom in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2008, 22:39 -
problem with tempgenc plus
By lancerx in forum Newbie / General discussionsReplies: 7Last Post: 6th Dec 2007, 02:35
