I just tryed to burn a 800Mo bin onto a 80min CD(hi-space 20x 80/700) with the use of cdrwin3.9a.
CDRWIN told the lenght was more than 75min and asked if I wanted to continue.
Told yes.
Burned.
Ok.
Read CD properties : 0 objects, 0 octets free.
I've done something wrong, but what ???
Thanx for helping.
It may be cuz you've used an blacklisted serial thats all i can think of try reinstalling see if the unregistered version works if it does then thats your problem
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
