    Nov 2001
    squeed
    I took a .AVI file that I created off of a VOB with FFMPEG. I opened the .AVI in Quicktime and exported it to a MPEG-2 file so that I can use VCD Tools to burn a SVCD.
    But Quicktime broke the .AVI into a .M2V and .AIF file. Why is QT doing that ? What I want is just a .MPG file that is MPEG-2 Compliant. (Audio and Video Together)
    How can you get a VOB to a MPEG-2 file going the easiest path?
    -S
    Jun 2001
    Silver Spring, MD USA
    Use mplex from the mjpegtools suite. FYI, since the Quicktime MPEG-2 encoder comes from DVD Studio Pro, it seeks to only make files 100% acceptable to DVDSP, i.e., elementary MPEG streams (and, in the case of audio, uncompressed PCM audio with an AIFF header). Using the Quicktime MPEG-2 encoder will make an MPEG-2 video stream thats outside the SVCD spec.
    Nov 2001
    squeed
    Can you tell me the best way to go from a DVD to SVCD ? I have been trying for months and I can't get it to work.
    MPipe doesn't work for me. It just crashes.
    I can't get any streams to MUX properly, the sync is always off
    QT Mutilator doesn't seem to do the trick either.
    OSex QT option is only for angles
    QT makes it's own version of MPEG-2
    AIFF's and PCM are not .MP2's and there is no MAC utility to convert them
    BBDemux takes VOBS to .M1V not .M2V
    I keep reading in this forum and it looks like people are cranking out SVCDs with no problem but I just can't get it to work right.
    Do you know how ?
    -S
  4. follow any of the proven processes available here
    http://homepage.mac.com/rnc/
    If mediapipe quits then remove the Mpipes folder, the app and everything and reinstall the latest version. Be sure you have Developer Tools installed.
    Nov 2001
    squeed
    I don't have developers tools installed, is that my problem with Mpipe ?
    FYI, I don't have it installed because my HD is partitioned and there isn't enough room on SYS Disk, can I partition again without loss of data ?
    -S
    Nov 2001
    squeed
    Major,
    Also, all of the methods on that page skip one major step. It says start with a high quality source from iMOVIE, DVD etc ... Then it jumps right to Quick Time. How do you get the VOB into Quicktime and synched properly, those steps are not included.
    -S
  7. Originally Posted by squeed
    FYI, I don't have it installed because my HD is partitioned and there isn't enough room on SYS Disk, can I partition again without loss of data ?-S
    no, if you partition again you will erase all the data
    check Mediapipe forum for more detail
    http://mediapipe.sourceforge.net/Forum/
  8. Originally Posted by squeed
    MissingMpegTools & Mediapipe allow VOB input
