what program can i use to make a menu(so that i can use the "next" button on my DVD remote)? like i have
5 different mpegs, and i am gonna make a VCD.
Some options here.
If you just burn the 5 MPEG files using NERO (or any other VCD burning software), it will automatically produce tracks that you can jump between with your FWD & BACK buttons. However, NERO also has a built in menu creator letting you add your own back grounds and then text for each track. You could also go and make a nice professional looking menu in any package that produces JPG or BMP files and just import these into the background for the menu.
Where NERO falls down is that if you have a single large MPG file you cannot jump to points within it. However, with VCDEasy you can and guess waht I just found on this site - see link below.
http://forum.vcdhelp.com/userguides/104503.php
Cheers,
Myth -
Where Nero also falls down are that its menus are authored correctly either and don't work on many software DVD proggies and even some stand-alone players.
I suggest that you use VCDImager +/- a GUI like VCDEasy.
http://www.vcdimager.org/guides
http://www.vcdeasy.org
Regards.Michael Tam
w: Morsels of Evidence
Make menu for a movie dvd that have subtitle and have not any Menu!
By p_samimi in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2009, 14:29 -
How do I make a menu for a video_ts folder that has no menu?
By ericg42 in forum Authoring (DVD)Replies: 5Last Post: 9th Jan 2009, 06:02 -
How to make a new Menu?
By chicodesouza in forum Authoring (DVD)Replies: 2Last Post: 22nd Dec 2008, 19:13 -
How do I make a menu?
By jbigfoot in forum Authoring (DVD)Replies: 3Last Post: 27th Feb 2008, 00:31 -
need to make a menu
By m-man in forum Authoring (DVD)Replies: 2Last Post: 5th May 2007, 04:19
