I read in another forum that even if you have a source DVD player with macrovision gone and region free (updated apex 1500 for instance), the Panasonic DMR-E20 or DMR-E30 will not make the copy to -R or -RAM. Does any one have any actual experience with this and has made just such copies?
I would also like to archeive my VCR tapes to -R using the DMR-E20 OR DMR-E30 but am wondering if i need one of those video stabilizers you see on ebay (for $40) between VCR and DMR-E30. Is there any other way around the protection than the $40 solution?
well its not macrovision its the Serial Copy Mangement thats incoded on all DVD's and its chipped for "no record" on ALL Home DVD Recorders, but I have found one DVD player that you can hack the Bio's that will allow you to backup any DVD, its the Sampo 631CF, sells for $169 I got a $30 rebate also on mine. I have both the DMR-E20 and DMR-E10 and using the Sampo for solely backing up DVD's I record works perfect, once the hack has been done, its a file burn on a CD-R/CD-RW that hacks it for Macrovion and Serial Copy Mangement free, get one in a hurry this won't last long as soon as Hollywood finds out they will make them take out this option.
I tried using the Sima Copymaster with my DMR-E30. It completely laughed at me and would not record.
On the advice of another site, I tried the Zorilla Video Filter (as far as I know, this is the name). It worked like a charm. So far, I have only copied VHS tapes.
When I purchased it on 10/18, it cost $139+$10 s/h.
The homepage is here: http://home.cfl.rr.com/filter/
An alternative you may wish to consider.
Panasonic DVD Recorder (DMR E75V) security dvd player restrictions
By paulmy in forum Newbie / General discussionsReplies: 4Last Post: 12th Jan 2011, 12:43 -
VHS to DVD (Damn Macrovision)
By ctdvd in forum Capturing and VCRReplies: 15Last Post: 3rd Apr 2010, 19:00 -
Help with cycling through/disabling soft subs from mkv->DVD conversion
By herbster in forum SubtitleReplies: 1Last Post: 24th Nov 2009, 01:44 -
Canadians - Verbatim DVD+R and DVD-R on sale Source at Circuit city
By victoriabears in forum MediaReplies: 1Last Post: 19th May 2008, 20:36 -
If a DVD player has no Macrovision…
By coody in forum DVD & Blu-ray PlayersReplies: 20Last Post: 17th Jan 2008, 17:20
