Hi,
I have a 20 min animation with some bad dropouts which I want to fix. I used VirtualDub to export an image sequence of the offending segment and was going to use the good frames I have to replace the bad frames. Before I go to all this work, however, the help files in VirtualDub aren't working and I can't seem to find an info on "inserting" the fixed image sequence back into the show when I am done.
Any help?
Thanks,
zim
You cant insert a single frame in Vdub, the only hope you have would be to load your images into a program that does animation, then save them out as AVI. Like Animation Shop 3 that comes with Paint Shop Pro, it can save as AVI.
If there is no sound, the you can re-join the AVI's with append in Vdub
You can also load the whole AVI into Animation Shop 3, and then you can copy and paste the frames. -
Thanks...I'll give it a try when I can...it has sound so I'm not sure what the best route is...maybe Premiere?
Converting .MTS to a .JPG image sequence?
By Anon1 in forum Newbie / General discussionsReplies: 1Last Post: 30th Jun 2011, 22:14 -
CLI batch Vdub Image Sequence
By corsiva in forum Newbie / General discussionsReplies: 0Last Post: 8th Mar 2011, 13:49 -
Image sequence - VirtualDUB - HuffYUV - washed colors
By Bucic in forum EditingReplies: 35Last Post: 8th Oct 2010, 15:42 -
Image sequence and easy x264 GUI
By Bucic in forum EditingReplies: 5Last Post: 4th Oct 2010, 17:03 -
best compression for image sequence movie ??
By mehdi0016 in forum Newbie / General discussionsReplies: 6Last Post: 26th Dec 2007, 10:17
