After creating several DVD-R disks I now face a dilema that maybe others are contemplating.
I created these dvd disks using mpeg-2 audio, which by dvd standards is optional. All the dvd players I put the disks in play them fine, even though the video was created with the mpeg2 audio instead of LPCM.
By DVD standards a mandatory audio stream of LPCM or AC-3 must be on the disk and any mpeg stream can be optionally added. For complete compatibility with DVD players you must use LPCM or AC-3.
I'm hoping I'm not creating a product that won't work in the future. I noticed software and hardware products are implementing PCM audio settings. I'm wondering if this is the sign of the future to come.
The only thing I hate about LPCM audio is that it is rather large and takes up more space that could be used for video quality. Mpeg is smaller and at present works fine.
I would really like your opinions on this topic. I am curious about what others are thinking about this situation.
Thanks,
ej![]()
You must be in the PAL region of the world. MPEG2 audio is not supported on NTSC versions of DVD (only MPEG1-Layer II, PCM, DTS and AC3 in the AUDIO streams).
I have often wondered about that requirement of an AC3 or LPCM file being required. Does the disk scan the DVD looking for these before it will play? I don't think so. Or, does it get to the end of a DVD, and finding out that it didn't play either one, say "you bad boy... I won't play this again"?
The way I would technically "meet" the standard is to have my FIRST PLAY PGC video have an AC3 stream (I usually get this from a commercial DVD). But then, most of my audio is AC3. -
My bad,
You are correct I am speaking about NTSC mpeg1. As long as it has PCM or AC-3 it is considered 100% dvd compatible. Yet if you create a video only using mpeg audio streams it is not considered 100% dvd compatible.
ej -
For whatever reason (I think the problem is in my HT receiver), the sound DVDs I encode and burn with MPEG-1 layer 2 sound isn't very good (problem only with digital coax audio input from player to receiver, no problem with analog connections). TMPGEnc and Cinemacraft only output layer 2 audio, as far as I can tell. The only encoder I know of that will output AC3 is the one in DVDit PE and the only encoder I know of that will output PCM is the one in DVD Workshop.
Anyone know of any other (high-quality) encoders that will give me AC3 or PCM in the final MPG file?
Thanks,
Alan -
scenarist has a good ac-3 encoder, of course it's like 10,000 dollars.
Their's always WinMX, not that I would encourage that.
BTW, if you can get away with AC3 or MPeg 2 audio go for it.
you'll get more media on a dvd. no PCM -
You can try the BeSweet suite of programs to convert your .PCM to .AC3 (or .MPA) audio. And it's even free. I use this program to go from .MPA or .AC3 to .WAV so I can do audio processing on my files (noise reduction, treble boost, etc). Just make sure that you get the latest version and ALL the required plugins - .DLLs.
Blu Ray LPCM or PCM? That is the question...
By hinsdale1 in forum Authoring (Blu-ray)Replies: 15Last Post: 19th Oct 2013, 17:36 -
How do you convert DTS to PCM
By ChrisDaMan in forum AudioReplies: 27Last Post: 29th Jan 2013, 02:32 -
iv50 pcm?
By dinofava in forum Video ConversionReplies: 9Last Post: 11th Oct 2009, 09:33 -
PCM vs AC3
By Reading Bug in forum AudioReplies: 14Last Post: 1st May 2009, 04:34 -
PCM to Wav
By woodie in forum AudioReplies: 2Last Post: 4th Jun 2007, 10:53
