When I try to recompress the Audio from a DivX 5.0.2 file I choose Full processing mode, No Compression, 44100Mhz Conversion. It gives me an error when i try to Save the wav.
It says, "The requested Audio Compression is not compatible with the input format. Check that the sampling Rate and channel count of the input match those of the requested format."
Can anyone help me out on this.
In Vdub select file > File information
What does it have for the audio codec ?
You may need to save out the audio another way and convert it later, depending on what you find.
Audio > direct stream copy
SAVE WAV
"Vdub AC3" may also help
http://www.digital-digest.com/dvd/downloads/virtualdub.html
Unknown audio in AVI files
By courtneye in forum AudioReplies: 6Last Post: 29th Sep 2011, 10:24 -
mp4tools/mencoder - compressed with an unknown/unsupported compression
By furrytoes in forum MacReplies: 4Last Post: 3rd Sep 2011, 08:48 -
YT audio compression
By -Sandro- in forum Video Streaming DownloadingReplies: 0Last Post: 26th Oct 2010, 07:25 -
How to install VFW codec alone for VitualDub?
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 29th Oct 2008, 16:44 -
Audio Compression
By Nitro89 in forum ComputerReplies: 8Last Post: 2nd Oct 2008, 09:00
