Well, I've just got my 104, and thought I'd have a go at the Ifoedit method with a dvd bigger than 4.3gigs. The problem I have is this. I've followed the tutorials and ended up with a VIDEO_TS folder and made an AUDIO_TS folder (which is empty).
The VIDEO_TS folder contains all my required .vobs and .ifo files. If I play the video_ts.ifo through "dvd play" in Ifoedit, it plays fine, and when I play the same file through power dvd it plays fine, with all menus, everything,
but...., when I try to burn the VIDEO_TS folder and AUDIO_TS folder in Primo it gives me the erros " Disc terminated with errors" and spits the disc out. This is immediate!!, it doesn't even try to write to the disc.
I've run vts sectors in Ifoedit and region free, and its verified everything. So if the ifo runs ok with Power dvd, am I to assume everything is ok??, and if so why won't Primo burn the two folders??
The VIDEO_TS folder is 3.89gb
I know primo is working ok, because I took the other method of Smartripper, ReMPEG, Spruceup on another DVD title and produced a .img which Primo burnt fine.
I just wanted to get my head around Ifoedit, and ended with this problem.
Thank you for any advice greatly appreciated.
Raider
