I NEED HELP WITH NERO..I WANT TO BURN A VCD AND IT IS ABOUT 40 MINS LONG, BUT WHEN I PLACE IT IN THE COMPILATION, IT SAYS THAT THE MOVIE IS LONGER..IN OTHER WORDS THE TIMES DON'T MATCH..WHAT CAN I DO TO FIX THIS? PLEASE HELP ASAP. THANKS.
JuPiTeR172
vcd_man40@hotmail.com -
1). check if your mpg file's bitrate=115000bps
2). check if your file is around 400mb
3). please write more about how to create your mpg file,
i.e. by which software, tmpg,ccstp.....
MY FILE IS MORE THAN 400MB(MPEG-1) AND IT ALWAYS HAS WORKED BEFORE AND I EVEN BURNED A VCD WITH A BITRATE OF 1900KB/S ND IT WORKED, BUT THIS ONE I AM TRYING IS 2000, THAT MIGHT BE THE PROBLEM..I AM USING TMPGEnc TO ENCODE.
JuPiTeR172
So, you are creating a xvcd not vcd, in that case,
under nero's burning process, you should untake the vcd compliant, and burn vcd as usual.
good luck
Help needed asap. Question about older TV and Blue Ray Players
By ccff22290 in forum Video Streaming DownloadingReplies: 3Last Post: 5th Jul 2011, 12:42 -
HELP! ASAP! Conversion .VOB to .AVI videos are jumpy!
By AngelVideo in forum Video ConversionReplies: 4Last Post: 20th May 2011, 19:36 -
Windows Movie Help ASAP
By OTH in forum EditingReplies: 2Last Post: 28th Feb 2008, 07:42 -
Guides needed asap
By demonwarrior in forum Newbie / General discussionsReplies: 3Last Post: 12th Sep 2007, 08:35
