  1. Currently Im creating XVCD's from DivX avi's.
    My player (Sony DAVS300) does not play SVCD'
    My settings are:
    Res 480x576 (PAL)
    Bitrate max 2300 (found through trial and error)
    CQ method at 90
    Audio at 128K
    The results are very good. I know that I could try to create SVCD and use the header trick to get it to play but I have a couple of questions
    1) Seeing as my res and bitrate are nearly SVCD spec, what is the point of encoding using MPEG2 rather than MPEG1 ? Is MPEG2 noticeably better quality ?
    2) If I use the header trick to get a SVCD to play in my player will I need to drop the bitrate to 2300 ?
    thanks
    Olli
  2. One difference is SVCD(mpeg2) supports interlaced video. VCD(mpeg1) does'nt.
    Craig
