Hi
I have this program but I have no clue how to use it.
All I want to do is back up my current system with all the drivers and such so that next time I format I can just reinstall everything from the CD
Little Help on where I begin
thanks
First make a ghost start up disc.
Reboot using that diskette
Select the drive you want to image and the drive to dump the image onto.
Select compression level
It will take anywhere between 20min to 1 hr depending on disk size, ALSO you may be asked to swap discs because it will be to big for 1 CDR. It will stop and eject the disc and prompt you to insert another, do so until done.
When restoring just do the same thing. -
i kinda want to do the same thing except i have 2001 and want to put all my stuff on a new hard drive that i bought
Your hard drive might have come with a disk that contains a utility, to transfer the data off of the old hard drive, onto the new one.
If not, then ghost your current setup and restore it on the new drive.
Originally Posted by mol3000 -
I have 2001 as well. I used it to transfer all my stuff to my drive when I replace my 6gig one with my current 40gig drive.
grrrrrr
i can't make a boot up disk
I keep getting an error saying IBMBIO.COM file cannot be found
what the heck does this mean???? -
http://service2.symantec.com/SUPPORT/ghost.nsf/docid/2000111511264225
for your boot disk problem
norton and spybot
By janefield in forum ComputerReplies: 5Last Post: 20th Mar 2009, 06:32 -
removing norton
By romanstopme in forum ComputerReplies: 7Last Post: 16th Dec 2008, 07:31 -
Norton Ghost 14 Advise
By Squid_uk in forum ComputerReplies: 9Last Post: 21st Oct 2008, 14:24 -
DVD on MCE 2002
By prabha in forum Software PlayingReplies: 0Last Post: 12th Oct 2008, 09:54 -
Dash you, Norton
By JohnnyMalaria in forum ComputerReplies: 10Last Post: 7th Dec 2007, 22:04
