I'd like some opinions from those of you who have used PowerDVD 4.0, or previous versions.
I have an ATI AIW. DVDs will play fine with ATI DVD 7.6, but I can only get mpeg2 files to play back properly with version 5.0. Specifically, there is a one second audio delay, when I skip around the file. ATI's software also tells me that some Directshow components are not properly installed. This was after a clean OS install, with sp2 and Directx 8.1. I repeated the process many times, with no change.
So, I tried using WinDVD, instead. DVDs and mpeg2s played back fine... until I left an mpeg2 file running, just to do a prolonged test. The video would freeze, after five minutes of play.
Anyway, I would rather not use any ATI software and I'm considering purchasing PowerDVD. My computer is currently getting "fixed." Both of my hard drives decided to crash, while I was rendering a file with Virtualdub.
Anyway again, I might as well gather some opinions/forewarnings before I get my computer back.
Thanks.
i have power dvd 4.0 and it has worked great for me. i have not noticed any sync issues at all on my system. IMO the best software player
PowerDVD
By BobbyScot in forum Software PlayingReplies: 1Last Post: 28th Aug 2009, 13:38 -
can't see anything on powerdvd
By Remyisme in forum Newbie / General discussionsReplies: 2Last Post: 10th Mar 2009, 12:18 -
Powerdvd keeps on crashing...
By uehara in forum Newbie / General discussionsReplies: 1Last Post: 27th Jun 2008, 20:58 -
PowerDVD 8.0 issues
By EAO in forum Newbie / General discussionsReplies: 4Last Post: 28th Apr 2008, 09:33 -
WinDVD 9 vs. PowerDVD 8?
By Vrex in forum Software PlayingReplies: 0Last Post: 7th Apr 2008, 22:54
