I converted 2 ASF files to AVI files, now i want to join the resulting AVIs...
when i tried to do this using VirtualDub, I got the following error:
"Cannot append segement: The audio stream have diffrent sampling rates (3.90625 vs. 3.36471). How do i resample the audio so that i can join the files?
Thanks in advance.
Schair1331
AVI 1
Audio > full processing mode
Audio > Conversion > 44.1Khz
Video > Direct Stream Copy
SAVE AVI
AVI 2
SAVE AVI
No Join with append, you could also use a MP3 codec instead of uncompressed, but its safer to save uncompressed incase of sync problems. -
I followed your directions, but I got the following error: "Cannot append segement: The video streams have diffrent sampling rates (25.20 vs. 25.00). Any idea how to set the video rates the same?
Thanks for your help so far. any suggestions are welcome. -
I new it would say that, seen a post the other day when the video frame was 25.1113 V 25.1113 and it still gave the error, as it could have been 25.1133334
There is no pleasing Vdub, but what I don’t understand is that your original AVI only had a Audio discrepancy, saving it out using streaming should have maintained the video.
Anyway, if you really want to continue with the join, then the best bet is to load each AVI back in and save out using uncompressed video... That will teach it to mess with you
Video > full processing mode
Video > compression > Uncompressed (RGB)
SAVE AVI
You could select the codec that is used to make the original files, if the file size is too big, once they are joined and they are too big, you would need to select a codec anyway, so maybe use the codec now
Video > compression > Codec (Same as source)
Uncompressed will give less chance of audio sync
I hope your not going to convert this to a mpeg 1 later, as all this is not necessary if that was the case
Join 2 AVIs
By phunkidude in forum MacReplies: 2Last Post: 23rd Dec 2010, 14:28 -
How do I join avis of different dimensions together? Or add borders?
By thedarkness in forum Newbie / General discussionsReplies: 9Last Post: 24th Jul 2010, 18:19 -
Trying to join jpg converted to avi with mp3 and upload to youtube.
By Yosho in forum EditingReplies: 2Last Post: 24th Apr 2010, 20:02 -
How do i join 2 AVIs with different resolutions?
By chocolate_brownie in forum EditingReplies: 7Last Post: 31st Jul 2007, 12:37 -
How can I join several AVIs into one?
By htp367 in forum EditingReplies: 2Last Post: 30th May 2007, 10:06
