  1. Here is what I do step by step:
    Enter CD-R into drive
    Select to make a VCD
    Move the mpeg files over to be copied
    Create the menu
    Click Burn
    It does its thing and when it is done, i put the movies in my computer (which plays VCD's always w/o problem) and it says either the disk is corrupt or the format is not valid for windows. What am I doing wrong that it isn't working?
  2. Has every VCD you have made (using the procedure you outlined) given you the same trouble, or have some of them worked?
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
  3. Try following this guide:
    http://www.vcdhelp.com/nero.htm
    If you are already following that procedure, please list the specs of your mpeg files and what software you use to encode them.
