Stargate comes as a double-sided DVD and I would like to back it up onto 1 DVD-R.
So far, I have ripped both sides to separate folders. Then I rempeg2'd them to the correct side (I added the VOB's together to calculate total VOB size). Then I demuxed the AC3 sound track from the original DVD.
This leaves me with a .m2v and .ac3 file for each side of the disc. I just want to combine them and burn just the movie onto a DVD-R.
I have tried to author using SpruceUp, but it only lets me add 1 video file. Is there a way to add a second video file and have it chain to it?
I am thinking that I will need to use some video editing software to merge the 2 files into one .m2v, but what about the .ac3 files? Any recommendations?
http://mpucoder.kewlhair.com/Derrow/joinclip.html#joindbl
that should work for you, i did gone with the wind and used it
New to double sided dvd's - Burning Hi Quality Media Files
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 27th Apr 2012, 20:50 -
Double-Sided, Dual-Layer DVD media?
By dgpretzel in forum MediaReplies: 22Last Post: 15th Apr 2008, 15:03 -
Dual-Layer Double-Sided DVD's turnover?
By Deisel Weisel in forum DVD & Blu-ray RecordersReplies: 6Last Post: 22nd Nov 2007, 21:23 -
do they sell double sided, single layer dvd's (DVD-10 - the ones you flip)?
By cduval04 in forum Newbie / General discussionsReplies: 12Last Post: 24th Oct 2007, 10:40 -
How do I convert double sided dvd to dual layer dvd?
By acid_burn in forum DVD RippingReplies: 2Last Post: 22nd May 2007, 04:04
