hi
i made a vcd that worked on my pc (windvd) but wouldn't work on my stand alone dvd. the reason i think is because when i was making it i made it was pal not ntsc. how do i check which one it is? and i used vcdeasy so how do i make it with ntsc? thank you!
my standalone is hitachi 305! thx again(sorry about poor english)
You logic is good ...that could be the problem...If you encoded with TMPG you can pick the template to encode with either PAL or NTSC.
But I looked up your stand alone on the compatiblity chart and the only 305's did not suport CDR or CDRW's ....This could more likely be the problem...see link.
http://www.vcdhelp.com/dvdplayers.php?DVDname=&DVDselect=Hitachi&Submit=Search&Search=Search
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 20:53 -
PAL & NTSC in the same camcorder
By griffmedia in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 24th Feb 2009, 11:55 -
Portable NTSC & PAL TV?
By Disco Makberto in forum Portable VideoReplies: 12Last Post: 14th Nov 2007, 22:31 -
Viewing quality between PAL & NTSC ??
By VEBouto in forum Newbie / General discussionsReplies: 24Last Post: 22nd Oct 2007, 12:50
