  1. does anyone use the fast XingMPEG Encoder? cuz i heard its really fast compared to TMPG...so i wanted to try it out but i dont know how to select the video source? i can select a d2v file..anyone fimiliar with it please help me
  2. Member xzarkad's Avatar
    Apr 2001
    Netherlands
    Then you also must have heard that the speed also causes bad quality. I cannot help you with this encoder, I just want to advice you to go for TMPGEnc.
    The Dutchman
  3. yeah i know about all of that, i researched it, i just wanted to see how much quality i would lose, cuz i heard Xing was 2 to 3 hours quicker than TMPG, i have been usin TMPG, but it just takes 5 to 6 hours on my 1300athlon with 256mb, so i dont know..i just wanted to expierment with the program
  4. Isn't Xing old and out of date? the last version I saw wouldn't even install on my W2K system....
    Feb 2001
    Rhode Island, USA
    The only thing of Xing's that I use is Audio Catalyst 2.1 to rip and encode all of my CDs to Highest Quality VBR MP3. The only MPEG encoder that I use that is not TMPGEnc is Panasonic MPEG Encoder Plugin for Premiere. When I am lazy and want to export something quickly, I don't use AVISynth to frameserv to TEMPGEnc, I just use Panasonic. But Xing? If it is quick like LSX Encoder, then it most likely looks like LSX Encoder's results, which look like you tried to capture 640x480 MPEG-1 at 200kbps on a Pentium 200Mhz. If you're familiar at all with this field of computing, you will know just what that would look like! Horrible.
    If you have the time and methods of acquiring this software, by all means post your results here when you're done testing and confirm our suspicions of bad encodes or tell us how great Xing is.
    irc.webmaster.com port 6667 #DDR
