Hi-I'm still pretty new to this but I have successfully made a few VCD's transfering VHS (Svideo,Pinnacle TV pro,Power VCR and Nero to convert and burn)All the VCD's have played in my DVD player but my main use is playing them in my Micron233mmx laptop's CDrom!---I just got this message on only one of the segments(2 hr VHS tape broken into 8 segments) In Nero it said I need to purchase a MPEG 2 codec? Why did it pick this one segment and not the others? Do I need to buy this? Any suggestions whould be great. Thanks Christie
if you look around the net you can find mpeg2 codec. there used to be one in the tools section on this site,check there
Hi--I installed the Nimo codec pack which says it has a MPEG2 encoder-I can't figure out why I get this message with only this one part of the video? It says something about a Patient licence and then directs me to Nero.com to purchase this codec! Why would all the other parts of the video be ok?It was a Madonna concert I taped on HBO. I'll keep trying Thanks Christie
it detected it as a non standard mpeg for some reason and wants to re-encode it for you i guess -- dont let it ..
Even when I selected to turn off the compliance it still gave me that message? Christie
Which Mpeg2 compression codec?
By yugurya in forum EditingReplies: 6Last Post: 20th Jan 2012, 00:35 -
proprietary codec used by Sharp for MPEG2
By ghostma in forum Software PlayingReplies: 17Last Post: 16th Nov 2011, 17:11 -
no sound on some movies when playing with ps3 and mpeg2 codec issue
By dhyane in forum Newbie / General discussionsReplies: 1Last Post: 14th Dec 2010, 09:18 -
Probable Codec problem. No audio on MPEG2 muxed files
By Kevlin in forum MacReplies: 14Last Post: 17th Apr 2010, 03:05 -
Virtualdub-MPEG2 - DV-AVI Video Codec For Widescreen
By minko in forum Video ConversionReplies: 16Last Post: 10th Nov 2008, 01:49
