I'm looking for an easy way to cut SVCD's into cd sized segments. MMC7.7 seems to do a good job of capturing MPEG2, S/VCD compliant files in real-time. So, all I want to do is chop a 1.2 GB file into 2 600 MB files that Nero will burn without re-encoding. TMPGEnc says "Your MPEG2 trial time has expired". The upgrade is 50 bucks and won't do DVD. I'm saving my cash for a DVD-R. So, I downloaded VCDEasy. All it seems to do is turn a perfectly compliant SVCD file into a .bin file the same size. I've got to be missing something. VCDEasy aside, is there still a free version of TMPGEnc that will edit MPEG2?
try bbmpeg in the tools section. its a better svcd cutter than tmpg and its freeware
Administrator Privilege to Run VCDEasy
By asifmcp in forum VCDEasy GeneralReplies: 2Last Post: 8th Jan 2011, 04:48 -
VCDEasy doesn't work in Vista...
By iThinkYouBrokeIt in forum Authoring (VCD/SVCD)Replies: 14Last Post: 26th Dec 2010, 20:20 -
Burning with VcdEasy
By gkma01 in forum Authoring (VCD/SVCD)Replies: 6Last Post: 19th Sep 2008, 20:00 -
Problem with creaing Menu in VCDEasy
By haris in forum Authoring (VCD/SVCD)Replies: 5Last Post: 16th Mar 2008, 08:17 -
How will I make an AVCD using VCDEasy?
By zeldAIS in forum VCDEasy GeneralReplies: 1Last Post: 4th Aug 2007, 15:13
