  1. What is the best way to get the ac3 sound off a ai filee
    May 2002
    Rainy City, England
    DVD Decrypter is as good as any for extracting audio from DVD, http://www.dvddecrypter.com/download.asp but you can also use DVD2AVI using the demux setting for the audio.
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    if its a muxed mpeg already on your HD -- tmpgenc can now demux ac3
  4. placing ac3 5.1 sound on a cd has no use right? cause it only has 2 audio channels
    correct me if im wrong
  5. Member adam's Avatar
    Sep 2000
    Ac3 cannot be used in a vcd or svcd and for the most part, yes both formats are limited to 2 channel sound. Svcd does support up to 7.1 channels of audio but the hardware support is so limited that almost no one can acutally use it. If your interested in this do a forum search its been discussed dozens of times but to save you some time, don't bother unless you have a Philips dvd player.
    Ac3 cannot be used on an audio cd but dolby digital can. It is possible to make dolby digital 5.1 audio cds. Read here to find out how, http://www.doom9.org/BeSure.html
  6. Член BJ_M's Avatar
    Jul 2002
    Canada
    you can also make DTS audio cd's - several different types in fact ..
    guides for that in same general location i believe -- or do a search .. DTS with 1.536mb/s bit rate is pretty impressive -- more so if you make a 20bit cd also ..
  7. oke thanks for comments
    but what i realy want to is
    i got a avi file with ac3 sound first i wanna get the ac3 souns then i gonna encode the avi file only video
    and then i wanna go to sprune to add ac3 sound
    but i wanna know how can i get the ac3 sound off the avi file
    May 2002
    Use the first part of DVD2SVCD and let it extract the sound then cancel DVD2SVCD, as it starts encoding with Besweet.
