1) Captured as DV
2) Converted to SVCD with TMpeg's "Super Video-CD NTSC" template (MPEG2, 480x480, 2000 kbps)
3) In TMpeg, went in "Simple Multiplex", dropped SVCD created above and set type as "MPEG-1 VCD"
4) In Nero, burned as standard VCD.
No luck. What am I doing wrong? I really want video quality and I'm not getting it with VCDs.
Thx.
Results 1 to 12 of 12
"What am I doing wrong? "
I have this player also, and no, it can't play SVCD.I don't have a bad attitude...
Life has a bad attitude! -
According to the reviews on this site, it CAN play SVCDs if you do some trick. I did the trick mentionned, but it still doesn't work.
Then believe what you like.
Whats the "trick"?I don't have a bad attitude...
Go to http://www.vcdhelp.com/dvdplayers.php?DVDnameid=241&Search=Search&#comments and search for "April 25".
Many people have said on this "DVD player comment" list that they successfully played SVCDs on the Panasonic RV-31 -
some more info http://forum.vcdhelp.com/userguides/97090.php
That didn't work either
With many people successfully making SVCDs for the RV31, I guess I'm the one doing something wrong, but I have no idea what it is.
The content of my CD is as follow:
\EXT
\MPEGAV
\SEGMENT
\VCD
\EXT\LOT_X.VCD
\EXT\PSD_X.VCD
\EXT\SCANDATA.DAT
\MPEGAV\AVSEQ01.DAT
\MPEGAV\AVSEQ02.DAT
\MPEGAV\AVSEQ03.DAT
\MPEGAV\AVSEQ04.DAT
\VCD\ENTRIES.VCD
\VCD\INFO.VCD
\VCD\LOT.VCD
\VCD\PSD.VCD
Does anything look wrong with this? I'm using 80 minutes Maxell CD-Rs -
Originally Posted by Lyverbe
-CV -
Sorry, "Cross-burning" isn't the prob. What they mean is that they remuxed a SVCD as a VCD so the DVD player will read the file header and load the SVCD. All of the posts you have read are not a lie. I own one and it works beautiful. Only advice is double check all settings in TMPG.
One question...there seem to be such a mix of responses to the SVCD prob that I wonder if there is a more definite way to identify which RV31 people have. Mine plays MP3's, while others won't. Maybe FCC#? -
chopy right in regard to burning your project, one of the guides here makes
mention of it, forgot which one?Also check TMPGenc setting when you remux the header as 'non-standard' for mpeg-1.
I have a Panasonic RV-26 with mp3 capabilty. The SVCD header trick did work to some extend. I had green macro blocks on the base (bottom) of my movies.
If all else fails try KVCD.net new templates, Although not SVCD quality, it yield admirable results for three of movies...
Orange County
Resident Evil
Imposter
Just my 2 cents,
Necro -
Hey folks,
I am the fool who posted that this player would play SVCDs if you told NERO to make a VCD and gave it a SVCD MPEG file....
I was new to the whole VCD thang, and I didn't know my butt from a whole in the ground. Nero was re-encodeing the file into VCD format. I didn't realize what was up untill MUCH later...
Sorry, it's all my fault....
<hangs me head in shame>
[edit]
<more shame for pittiful spelling>
VCR comparison Panasonic NV-FS200(AG 1980) VS Panasonic NV-HS1000
By JoseD in forum RestorationReplies: 32Last Post: 18th Apr 2016, 08:30 -
best vhs playback? panasonic nv-fs200 hq / panasonic dmr-e75v
By overheat in forum Newbie / General discussionsReplies: 6Last Post: 28th May 2009, 20:57 -
Panasonic DMR-EZ28 Previously Recorded Panasonic DVDs
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Oct 2008, 20:45 -
black bars on sides of screen, Panasonic s97 to Panasonic e55
By southland66 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 10th Sep 2008, 17:15 -
Panasonic AY-DVM83MQ vs. Panasonic AY-DVM83PQ and AY-DVM80XJ question.
By Cyrax9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th Feb 2008, 12:37
