I was wondering, what's the best way to convert the std. NTSC 29 fps down to the PAL standard of 25 fps? I've been using TMPGEnc by just loading the setting of the VCD I wanted (PAL), and then just converting it. However, I notice slight choppiness from time to time when watching my converted movies.
Is there a "perfect" way of going from 29 to 25 fps?
Your help would be muchly appreciated
-silentzero
Wimbledon, UK
I don't know of one. With NTSC(film) you can change the framerate and shorten the audio, but the difference is just too much to do that with NTSC to PAL. However you do it, frames will need to be dropped, and this will be noticeable.
Is the FPS of a MiniDV camera higher than the FPS of DVD video?
By granturissimus in forum Newbie / General discussionsReplies: 8Last Post: 9th Jan 2011, 05:40 -
mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
By perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 22:42 -
how to change fps in mp4 without reencode (maybe ps3 cannot handle 24 fps)?
By redout66 in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2010, 04:53 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17 -
choppy fps with vsoconvertx
By NateDizzle in forum Video ConversionReplies: 13Last Post: 11th Jun 2007, 12:50
